City Navigator® Europe NT 2013 10
Ash
Oh Yes....
Earth
Wont fit on my Zumo 550.
Any ideas,would be great.......... :thumb
i can load central,but that does not have scot/wales/ireland or NI
Is it not possible to download them to the puter then copy to a SD card?
(I'm only just starting out with all this so bear with!!)
down load all to putor but only put on s/wi/ni to zumo,then when you go to europe download them areas to a sd card
Got to work out how to load SD card :blast
FFS......
Just did mine tonight. It took a good couple of hours mind. I put north and west Europe on mine and it fits ok.
Just depends where you wanna go!
Here you go Ash, this is the link
Have you installed the mapping to your PC. If so download MapInstal from the Garmin website. Best to plug your SD card into a reader as this will make writing the mapping much quicker.
MapInstall will show the mapping you have on your PC, select the areas of mapping you need, the selected tiles will turn pink, and then click next and finish to write the mapping to your card.
So long as the mapping on your PC is unlocked to the Zumo that you're using it in should work.
That was easy - Installed -City Navigator® Europe NT 2013 10 Northwest Partial Region onto Zumo 550.
Then clicked onto Garmin BaseCamp - put 8GB card in computer and transferred all of City Navigator® Europe NT 2013 10 onto card.
So all in 550 now...
Top man, knew you'd suss it Ash :clap:clap
