Bin Ridin said:
Hi,
I was looking for a deal on Aspid.com, but no sign of CN V8 so this made me think CS V7 would do the job. It is offered for about 100 quid. Even if no upgrade, it seems not too bad ??
When you buy an Automotive Kit for the 276C from Aspidshop you get -
- MapSource (the PC program) license and CD
- Map V8 license (but not the DVD)
- 256 MB map memory chip
- Power and data cables
- Car mount
In the box you will find CD's with the map V7 and a Cupon Code. With this Cupon Code you can retreive unlock codes for both V7 and V8 of the map from
www.garmin.com. The DVD with the V8 map you can order free of charge from Garmin Europe.
Note - there are no maps on CD for sale that can't be upgraded to V8. What you buy is only the Cupon Code and that entitles you to the most current map version. Also don't forget that the PC software MapSource is required to use the map and so is the memory chip.
Bottom line: Don't buy a map CD only. Buy a complete Automotive Kit. The only situation when you can buy a separate map is when you already have an Automotive Kit for one region (USA) and want a map for another region (Europe).
Depending on what you actually have you may already be half way to an Automotive Kit. Maybe this is what you can do:
- I assume you already have all mounting details & cabling OK.
- I assume you already have MapSource? Try to install your MapSource CD on your PC. Does it run? Can you upgrade it to the latest version at
www.garmin.com? If successful - fine!
- Do you already have an empty 256 MB memory chip? If not buy a 512 MB chip from some internet site in the US. Price $150.
- Buy the CN7 CD you are talking about. Check that there in an unused Cupon Code comming with it! Login at
www.garmin.com and retreive the unlock code for V8. Order a free CN8 upgrade DVD from Garmin UK.
Good luck!
