Welshman
So I agreed to help someone with an 1150 GSA "drive problem" like there was none
Step 1: should have been 2 but anyway, pulled slave cylinder, yes leaking horribly, so assume clutch wet, (could turn rear wheel in gear) so pulled box and swapped clutch, slave etc, there was fluid in the clutch area but not enough really for symptom, but clutch was at minimum anyway
Step 2: rebuild, bleed it all, grab rear wheel in gear still turns
Step 3: pull gaitor on bevel box, yes lots of sticky rubber stuff, fit new drive shaft all cool
Step 4: Test ride, idles OK, good clutch, box etc etc, but it doesnt pull from the bottom like mine, mine is an old 99 single spark versus this 2002 I think GSA, so I pull the aux plugs, both are sparking like heroes, pull the primary stick coils nothing no change
Both of them dead, this has been an expensive weekend for my mate
