Clutch Leak
FoxCorp
Member
London
My bike seems to have developed a leak from the clutch master cylinder and wondered if anyone has seen anything similar. It's a 2021 1250GS and I thought that it was leaking from the joint where the hose screws into the reservoir, but it's been into the dealer workshop & had it checked out, refilled and that bit is all good. But it still leaks,
After cleaning it up and keeping an eye on it, it seems to be leaking from around one of the the holes where the screw is for the cover. I can't see any cracks or damage on there and haven't touched the bike for weeks, so don't know why it's suddenly started.
There's a new second hand one on the way to replace it, so I'm sure next post will be about how to bleed the clutch line!
I had a similar leak like yours , I put it down to over filling the reservoir I just kept a eye on it and it seemed to sort itself out.
My 2021 GSA was in earlier this year with BMW for a leaking clutch master cylinder. Repaired under extended warranty. I initially had problems with the clutch lever. The biting point was right at the end of the lever which made hill starts a bit scary. BMW investigated and found it to be leaking. Repair didn't make any difference to the clutch problem though. Still trying to figure that one out on a bike that only had 17k on it when it started with the fault!
