can the gearbox be removed whilst being attached to the swingarm to get to the clutch, to change it?
if so how , n can i realign the drive shaft if its not moved...
am tryin to cut corners , so to get at clutch , and not have to remove swing arm pivot bolts. ye know the ones that have to be torqued up on reassembly.
obviously ill have to support the gearbox as to not bend the clutch push rod
so the whole rear end has to be lifted ,and fekin abs removed .
is this possible , or am i makin it hard for me'sen in the long run?
ugg
ugg
