Clutch Slip
red rocket
Norfolk U/K
Didn't have a good day yeaterday 9 month old 1200 standing for less than a week battery flat as a tad stuck my car charger on it (probably shouldn't have ) started ok .
Ferk me out having a blat the cluuctch starts to slip.
Pulls over checked to see if too much fluid in it no that was ok went to adjust the little lever adjuster couldn't pull the lever back so gave it a tug and it moved to give some free play .
Pleased to say it cured the problem ,so although the lever was working ok some how it wasn't returning fully allowing the free play normally there .
So a spray no again again me thinks wouldn't do it any harm
If it's the cluch lever you are talking about, often the hand guard gets knocked and touches the lever end preventing it from returning fully, very common problem.
No youv'e lost me here???? Are you typing in Norfolkian :)
Yar right ba .:thumb
In answer ta the previous post no it wasn't touching on the hand guard it was as if the spring loaded bit where you open the lever more to adjust the little black nob it had seized in that bit .
:beerjug:R.R.
