Gunboat Willy
1150GS - approaching 20k miles.
On hols recently, two up with a reasonable luggage load. On some hill starts the clutch didn't seem to 'bite' until the last few mm of clutch lever travel...in fact it seemed to slip. On a couple of occasions I'm sure that I could smell clutchy/resin-ish smells too.
It seems to indicate that the clutch has had it/is worn out.
Reasonable diagnosis? If oil had got into the clutch would these also be the symptoms? If worn out - anyone else had a clutch that only lasted 20k?
Ta.
Ta.
