Yup, hence if you go offroad BMW suggest maxing out the front preload to really slow down the steering and raise ride height.
Preload raises or lowers the ride height of the bike, front for the front and rear for the rear.
Standard shocks - Compression damping is only available on the rear via a screwdriver adjustable slotted screw, this will make the suspension harder or softer, there is no adjsutment on the front.
Adjusting the preload does not adjust the damping of the shock.
