Set of 4 x genuine BMW X3 wheels with Continental Winter Contact TS870P tyres.
They came off my previous X3 2.0 diesel (F25 model) 2010-2017
Wheel size: 7.5J/17 ET32
Offset: 30-34
Centre bore:72.6mm
PCD: 5x120
Thread: M14 x 1.25
Tyre size: 225/60/17 V XL
The tyres were only used last winter for approx 3,000 miles and are in excellent condition with approx 7.5mm tread remaining (see photos). I paid just under £800 for them in November last year and they are consistently rated in the top 3 of winter tyre tests...check them out on the winter tyre reviews.
The wheels are in good condition with no buckles, dents or kerbing marks, but there are few small areas where you can see some salt corrosion. The TPMS systems worked fine on all the wheels when I took them off my car in April.
It's so much easier to have a dedicated winter set, rather than swapping summer/winter tyres on the same wheels twice a year.
These may fit other cars, but please do your own own research to check based on the info above.
The only reason I am selling these is because I now have a newer X3 and both the PCD and wheels sizes are different.
NOTE:
It is normal for cars to run narrower winter tyres to increase surface pressure on snow and ice. If your X3 (F25 model) normally runs on 245/50/18 wheels and summer tyres as mine did, these will almost certainly fit your car.
£500 collection only from near Oldmeldrum, Aberdeenshire, although I could meet by mutual arrangement within 50 miles or so.
Offset: 30-34
Centre bore:72.6mm
PCD: 5x120
Thread: M14 x 1.25
NOTE:
