colour of live wire feeding 1200ADV Aux socket?
darkhorse
Sydney
anyone know which is the live wire feeding the aux socket on the new 1200ADV
Assuming it's the same as "basic" 1200...
I recently resoldered my connections...
should be Red/Green stripe (brown is the neg. IIRC)
live connects to the lower pin on the socket
you can double-check by multimeter - with ignition switched on live probe to centre of socket and neg probe to -VE terminal on battery will give 12.x volts (the same to outer part of socket gives nothing) - it's a clip (top and bottom press with fingers) connection at the back of the socket - repeat same with wire connection.
Just as a matter of interest what are you going to wire up ?
I'm assuming it is the same as R1200GS - the ZFE unit seems to detect excessive current draw and can switch off that circuit - there is a thread about it somewhere that suggests this might have something to do with a software update - in either case it's still a problem for me and my heated jacket thermostat :spitfire
Was going to wire gps, heated jacket and autocom. On reflection I better read the threads, and may just put the autocom to the aux socket, and wire gps and jacket staright of the battery
