COmpression low - should I get the spanners out?
waterloo700
Perth, scotland
Tested my cylinder compression (1100 1998 52,000 miles) and it's in the "poor" band at 115/120 psi. I don't have any previous readings for the bike so can't tell if its a sudden drop or gradual deterioration. The bike starts and runs well and I'm reluctant to fix what might not be broke. Previous threads suggest the 5 psi difference left to right is not bad.
Should I overhaul the heads over the winter or leave them alone and see if compression drops further?
Would I see a noticable difference if I did the work and could get the bike back up the the 130/140 psi mark?
Any advice welcome
for me the moral of your post is.. don't go looking for problems.
ride the thing. :thumb
Any advice welcome
If its not affecting performance too much I certainly wouldn't open er up.
It could just be a piston ring gummed up.
Try a shot of Redex in your tank.
Might help. Doesn't cost much and won't do any harm.
Was it warmed up ? Was the throttle fully open ? was it this ? was it that ? ... Just ride the thing and leave it alone !
If the bike was / is running well .... why on earth even do a compression test?
I'll stop now :)
Yes to all that - I'm new to BMW's so "running well" is all relative.
It was running out of steam at 180 two up. Had Kylie Minogue on the back and she's clearly getting a bit of a lard-arse. She'll have to go.
Only 180?definatly something wrong was this is top?
Welcome to the world of GS's. As you will have already guessed, BM boxers are "kinda different". One of these traits is to take several nuclear half lifes to run in so even at 52k miles it may have been ridden by a pipe smoking vicar (or even a Beemer rider, ahem) at low to no revs for much of its life.
Give it some stick for a bit and you will probably free it up a treat and burn out any crap. Probably use less oil as well. The engine bit is usually very solid and goes on for several owners.
Have fun:D
