Controlling 4 lights
dicktheleg
Pestie to the Nobility
Worcestershire, England
Is there a way I can control 4 front lights on my bike such that the lower 2 are on all the time bit at different intensities day / night / dip / main ( also extinguish with indicators) then have 2 long range spotlights that only come on with main beam, all controlled by the Ezcan?
TIA
Rich
TIA
Rich
Yes, is the short answer!
The 2 you want on all the time and to go off with the indicators you want a separate circuit for these (1 left, 1 right). You can set the running light brightness/main beam brightness & the go off with the indicators.
The 2 you want on with main beam can run off one circuit (so long as total Amps doesn't exceed the limit) - you can get a splitter to operate this. For set up you'd set the dip beam/DRL to 0% brightness and main beam to whatever you want.
My learnings are from the Denali CANsmart, but i believe the Ezcan is the same/very similar in its functionality.
Much obliged, cheers 👍
Its made by EZcan for Denali
TIA
Rich
Yes just ensure they are run off a separate circuit as already mentioned
A Bike Thing (the company) does some very good videos on Youtube about what you can do using the EZcan/Denali cansmart devices
