Corbin seat on an R1150RT
Steptoe
Him/Bloke/Fella.
S/W London.
Is the rear seat a bit wobbly when it's all fitted ?
Just got a corbin off ebay and you can move the rear seat up and down a couple of inches - is the rear locking bar under the seat different on a corbin ?
The standard seat is a looped type locking bracket, the one on the corbin i have is a bar/pin attached/fixed to the base at one end only :confused:
Mine is not loose right at the back, but there is a little play up and down where the front seat connects to the rear seat, but not 2 inches.
Can you not put the same OEM loop catch on the RT seat from the BMW seat, that's what I did with the GS (albeit with a bit of packing with some washers)
It's a while since I've had a Corbin on an RT (2 years ago) but mine fitted ok (but only in the front seat, middle setting, rear seat wouldn't fit, with the front seat in lowest or highest seat settings:blast)
