Corrosion on swing arm
If the swinging arm is visibly corroded have no doubts that the engine cases will be worse (unless it had a new motor fitted under warranty due to corrosion ).
To properly sort out such corrosion is not a 5 minute job and if you want an immaculate bike it will cost £100's to sort it out
