Glad you got it sorted out through the warranty
When I had my 1100, I used to do my best with cleaning and ACF50 to protect it and reduce corrosion.
It's pretty severely anal, but when I ran it through the winter, I took to dissolving ACF50 'Corrosion Block' grease in naphtha (panel wipe) and painting it on vulnerable bits like the fork legs etc. The solvent forms a carrier and makes it loose enough to 'flow' and seep into joints etc but it evaporates leaving the grease behind. When I part exed it before Christmas, it looked pretty damn good for a 20 year old bike and certain bits that had a name for corroding (fork leg brace, fork legs etc) were immaculate.
I've just done similar with my 'new to me' 4000 mile TC to back up the ACF50 that I've already all lathered over it. I've blobbed a little dissolved grease onto all the spoke nipples, disc to hub joints, crash bar joints, vulnerable fasteners etc (although I've not painted it on to whole components like I did with the 1100
The grease itself isn't cheap but it's great to have anyway and I use either it or duralac ever time I remove a fastener (I stripped the tank panels and beak off last weekend to fit an oil cooler guard - everything got greased / ACF50'd while I was in there). It's an excellent thick EP, high temp corrosion resistant product and it's 'clean' if that makes sense with a grease.
