COST EFFECTIVE AUX LIGHTS
trainman
NORWICH, ENGLAND
Wanted some extra lights to awaken dozy types on commute. Didn't want high power or relays or complicated HID with Canbus issues etc etc. Just simple stuff. Also wanted a set up that could be removed quickly if needs be without leaving holes.
Found these 4 LED lamps at bikevis.com (£60 pair or £50 if you have bought something from there recently). S/steel powder coated bracket made locally at Rackham Engineering (Norwich) for £50, this clamps to bar in front of oil cooler.
Light is not focussed like a spot but bright and blue enough to stand out (300 lumens) and does give some good extra road lighting at night. They do have the E and CE markings too.
As they only take 1.2A total I have them on a switch then into the unused SatNav feed from Canbus.
Any reasonable comments welcome!
well done mate - i was quoted £388.63 plus fitting by local bmw dealer for oem led auxillary headlights
