Could someone please post a picture of your OE Fog light switch
Adventure Boy
Romford Essex
Hi Guys
Installed a set of LED fog lights but could do with them being switched really
Ive seen some OE fog light switches on ebay but cant find what one is for the LC and where it fits
If someone could post a picture of theirs id be very grateful
Rob :thumb2
Here you go. It is an add-on held by what seems that one screw at the bottom
Sent from my SM-G930F using Tapatalk
And as expected the pics loaded upside down :blast !!!
Now then guys, bit of useful info you, the original equipment switch (I believe) is a push for on, push for off switch that needs connecting to a micro circuit or direct to the canbus, it's not a rocker style switch.
Anyone managed to wire one up.?
Doesn't it mount to the mirror bracket?
Yes it does, but the original mirror clamp doesn't have a threaded hole for the switch retaining screw, I believe the replacement clamp with the mounting hole comes with the switch kit.
Hi Guys
Rob :thumb2
Rob
I have a spare switch if you want it? just contact me directly, yes it does need to operate via existing harness / can-bus system
Chris
Chris thanks mate that would be much appreciated cant seem to send you a PM though if you can PM me ill reply thanks
Rob
Chris
I was going to use one connected to my Givi lights. I'd have thought it was just a simple switch and could be used with my Givi loom.
Is the warning light on the dash as standard even though the lights aren't?
Hi
So switch connects to the can bus, is there a socket for the lights already on the bike? if so, how is it identified.
I am already using the one for the satnav.
Thanks.
Hi
Thanks.
Any switch connects to the wiring on your bike. The wiring works based on the canbus protocol/language.
If you've already used the one spare, the only option will be for you to plug direct to the battery using a relay or a power distribution module such as the HEX EZCAN or a PDM60.
Ride safe.
