A couple of quick questions if I may
When I'm manoeuvring very slowly and in and out with the clutch I'm getting a metallic clanking sound as the clutch bites/releases, the clutch seems to work fine and it's only at silly low speeds moving the bike in first gear. Is this normal ?
Also, how much backlash should there be in the final drive and is there a way of knowing if there's too much or if there's a problem ? I've read about the FD failing but what are the signs of this happening ?
This is all new to me
