ianran
Does anyone know of rubber handlebar mount kit that works on a 2011 GS? The vibes are numbing my hands and I have an Iron Butt to do! Ive tried Grip Puppies but a bit to lardy on the grips for my liking.
Try a throttle lock set it quite loose so the throttle will still close just more slowly so you can stretch your fingers without the throttle snapping shut. You will find you don't have to grip the throttle as hard just resting your hand around it will hold it in position this works for me.
I have the Rox anti vibe risers but the risers work best at 90 degrees to the vibes so on a boxer they need to be vertical. This makes them way too high even with lower mounts.
I also looked at getting some Flexx bars http://www.fasstco.com/product-category/flexx-handlebars. They look great if a bit(?) pricey but the GS vibrates horizontally and these are built for vertical forces. The guy from Flexx suggested I use Rox risers AND their low rise handlebars. I'm not that rich and it could end up very sloppy and loose feeling.
Another option is a Tuned Mass Damper. Vibranator said they took a while to develop something for the GS bars due to the 12mm thread and small internal bore. http://www.vibranator.com/street_bikes_s/23.htm?searching=Y&sort=5&cat=23&show=10&page=2
So are they too compromised? Maybe something from Fasst mounted below the handlebar with a stiff bracket from the bar end would be as good. But what are the correct measurements? Other than a bar to create an antiphase vibration who knows?
For a quick & dirty solution wrap the standard grips with some 3mm Sorbothane sheet. The edges can be superglued to make a tube. I have tried this with some cheap anti slip rubber mesh. It helped and showed that £20 of Sorbothane is perhaps worth a try.
Last of all (or maybe first), check the valve clearances are exactly correct not just in tolerance and that both throttles are balanced.
Grip Puppies have helped me with vibration. It's a cheap solution and worth a try.
Was having the same problem. Grip Puppies solved it.
Just don't put too much washing liquid on when fitting them or you'll need to wait three days before you have throttle action again. How do I know![]()
