For Sale: Custom-Shortened Öhlins STX 46 Rear Shock (BM 332) – 450mm for BMW R80R / R100R Paralever
Genuine Öhlins S46DR1S (BM 332) rear shock absorber in very good used condition, removed from a BMW R100R. Custom-shortened from the stock 474mm length to 450mm eye-to-eye—ideal if you are looking to lower a 1991–1995 BMW R80R or R100R Paralever (drops seat height by roughly 30–35mm) or building a Paralever scrambler/cafe racer/bobber project.
Specifications & Details:
Removed from a running R100R and clean throughout with no leaks, a clean chrome shaft, and working preload and rebound adjusters. (Note: Too short for a standard R80GS / R100GS / GSPD, which runs a 495mm shock).
Price: £365 OVNO including UK tracked & insured postage
- Model / Stamping: Öhlins BM 332 (S46DR1S)
- Length: 450mm eye-to-eye (shortened from 474mm standard R80R/R100R length)
- Mounts: 10mm top eyelet / 15mm bottom eyelet (direct bolt-on fitment for Airhead Paralever models)
- Spring: Öhlins 1091-24/80 (80 N/mm rate, 160mm free length)
- Adjustments: Hose-mounted hydraulic spring preload adjuster (black twist knob) and rebound damping adjuster wheel at the base
