Customising My Motorcycle Info.
midnight runner
Member
North Yorks
Is there a way to re order the 16 fields in the motorcycle info.
I'd like to mainly display speed when not using the nav but mine is displaying front tyre pressure and I cant seem to re order.
I've had a look in the manual but cant find anything.
Press on the one you want to change, then scroll down to the one you want and that’s about it. Have the top four as the ones you use the most then when you rotate the jog they will display in the four segments
Thanks for that. I've had a play with it and it is as simple as you described.
I am a bit of a technophobe, as my kids will attest.
