Cutting out (not surging)
(RIP) Boxertools
West Norfolk.
Can anyone help?
I have a problem with my R1100S, "yes I can hear you saying, the problem is, it's not a GS".
But seriously.
I can be riding at 70/80 and when I ease off the gas, it dies as if the ignition has been cut.
When you come back on the gas, it comes back like a switch being turned on.
I took it to my dealer some months ago with the same problem & they put it on their diagnostic machine.
It showed a potential potentiometer problem.
They replaced the pot, but the problem remained.
Having given up, they put the bike back together & the problem was gone, until now.
Mike h.
Shows all the signs of a potentiometer fault. If they have replaced the pot then it may be in the wiring, bad/loose connection somewhere. Not fun to find. BTW BMW wiring is cack.
Have a look at the side stand switch,pain in the arse things they are. If not that, have a look for corrosion on the left hand throttle body electrial conection. Just disconect it, and have a look at the two pins inside. Give it a squirt of WD40 anyway, it won't hurt it. If it's neither of those two things, then I'd go and get a grown up.Good hunting.
ps. let me know if you find out what it is. cheers
Thank you Panzer & Vern, I will look at those things later.
Vern, I wonder if you could supply a set off those S/steel fixings for my bike?
I spoke to Mike o & he said they may not be the same as on the GS, but I would be happy to take a set with extras.
Mike also said that he wanted to settle up with you on the postage thing, so I could include that in my payment.
Mike h
Boxertools(if that is your real name?) If you go to the inovators and invetors thread. You'll find all you need to know.If you get stuck, give me a bell on 01905 612705 tomorrow
Tools,
Sounds like it could be hall sensors!
Just had this problem.
Are running as normal, back off a bit (when Changin gear?) revs plummet engine cuts out(ish), gun the engine, it's running again.
Hall sensors come on a plate and live at the end of the crank, normally called points - one manages tickover, the other on the run - they don't take long to replace (two screws and a plug), and don't cost a mint.
I am reliably informed that it is not an uncommon problem with any R engine, but not regular either.
But
Call your nearest dealer and mention HALL SENSORS - DO IT NOW. As once it's popped, it'll stay stopped.
Good Luck
Jamie
Jamie,
That sounds like the same simptom to me.
OK I'll tell my dealer and see what they can do.
Mike h.
