I'm just in the process of ordering up parts to strip the heads and barrels on my 1978 80/7. I have a spare engine with one side stripped and there seams to be no groove for an O ring on the barrel base and there was certainly no barrel base gasket so the question is what seals the barrels to the crank case, do I need O rings?
Also should I replace the external circlips on both ends of the gudgeon pins even though I will only remove one to release them from the pistons?
Thanks bubbles.
Thanks bubbles.
