- Joined
- Nov 5, 2015
- Messages
- 13,626
- Reaction score
- 5,892
Yes, you need to remove the coil stick, you can do it carefully using 2 flat screwdrivers or even cutlery knives if you don’t have a puller.So, to remove the cylinder head cover does it also involve withdrawing the coil on the spark plug? (Special extractor required?) & is there any oil loss, do I need to drain the oil?
you don’t need to worry about scratching the cover
leave the bike on the side stand for 5 minutes as you’re replacing the right hand cover, you’ll only lose a couple of drops of oil, you won’t need to top up
use a torque wrench to put the screws back in, apparently they’re easy to strip if you over tighten them
