I've seen at least 5 personal accounts on Facebook of the screens being nicked. I'll assume they aren't lying, one guy had his nicked twice in Central London.
Always good service at CymarcQuick update in that Mark from Cymarc is on the case to help resolve. Hopefully something simple, but must say I'm very impressed with the instant assistance!!
Having seen your "problem" @GSMarky, and having received my brace (same as yours) last week as well, I thought I'd fit mine, just to check. So screen off, plastics off (as per instructions), decided to fit the longer bolts, so took the 4 OEM bolts out and replaced them with the ones supplied by Cymark. And that's where it went wrong for me, offered the brace up, could not get it to bolt squarely down on the face of the TFT. SO rang Mark at Cymark, who really could not have been more helpful. A few pictures swapped, a few suggestions made and the brace fitted on 3 corners - but not the fourth. Further phone calls with Mark and I said I'd pull it down yet again to find the pinch point. Which is when I found the problem - user error. What had happened was that when I took the 4 OEM bolts out to replace them with the longer bolts, the Sat Nav bracket had slipped slightly on the nearside, such that when I put them in, I put the top bolt through the hole in the bracket instead of using the proper hold just underneath it. Offered up and bolted up the bracket again - and bingo it just perfectly slotted into place on the TFT and bolted up no issue at all. So user error doh! Rang Mark up and apologised and thanked him for his assistance and help which was outstanding.
So just wondering @GSMarky whether your problem might have been similar to mine?
Picture attached now its fitted
Would any attempt to remove or disconnect the TFT set of a BMW factory fit alarm?
no it wont
That's disappointing, presumably the TFT can be removed so gently that the tilt sensor for the alarm isn't triggered. Also surprised that disconnecting a core piece of the bike's electric system wouldn't trigger anything, seems like a basic alarm function to me.
Mr Hooten does your brace fit with your screen braces?
MkI v MkII TFT Braces by KTM Marky, on Flickr
MkII Brace Fitted by KTM Marky, on Flickr
