Thanks for the info , i have now found its a fuel problem , as after trying to start it with no joy , i found the plugs bone dry ? and would have expected them to be wet with fuel with all the spinning of the engine , i have replaced the the fuel pressure valve and am yet to see if that works . i have noticed that when i remove the injectors the fuel just pores out of the pipe ? is this normal ?.
I am going to try and see if the presser is up when i crank it over as i would expect that or am i wrong[/QUOTE
Sounds like blocked injector..sorry if you've replaced it before..didn't follow all your posts...
