Dark outside
slimpickings
Doncaster
So have added these
The little green light in the bottom left is the switch
Which ones are they, from where, how good are they at night and how much?
I am thinking of getting something similar.
Thanks.
Thanks.
Take a look at Fanums - I've some on order so will report back soon. They look the business :thumb2
Thanks.
WUNDERLICH MICRO FLOOTER
Bought em at Rainbow
Very good at night , no problem with oncoming traffic
about £120
2 lights fully wired harness with relay .in line fuse, waterproof illuminated on off switch and precision fit bracket plus all the nuts bolts , and instructions that any one can follow
they even put the shrink wrap in the kit
Fitting them on an RT without the bracket would be near on impossible
Space on bracket to fit some long range stuff from Fannum as well:D
Wary of tapping into the loom on my rt with the can-bus system? Any pointers on a safe way to do it without blowing it up?
Sounds like the flooters are straight forward enough with the loom and fittings supplied etc.
thanks.
Sounds like the floaters are straight forward enough with the loom and fittings supplied etc.
thanks.
The kit is idiot proof
(Needs to be for me)
The connection is made to the battery
So no canbus issues
Then to an in line fuse and then a separate relay
It is all ready put together when it arrives
You don't need to solder,crimp or use your brains
No wires to cut or joints to make
seeeemples
They even put a zip ties in the pack
If you want more info
Go to the Wunderlich site and you will be able to download the fitting instructions
Buy it from Rainbow , then have a ride out to collect it
No postage
Splice 'em in?
That sounds easy enough- i'm quite happy to do the wires/relays etc. So do you just splice the bullet markers into the wires to the flooters? Cheers
Aha the bullet markers
I just spliced them into the back light
However.... my bike is an 1150 RT
They are L E D and only take a tiny current
so they may work on your canbus thingy
Somebody will probably pop up and say I am talking bollox:D
Yeah, not sure about tapping into the wires to the back lights, but figure it would be okay on the flooter wires as they are on a separate 'proper' circuit.
