De cat headers question.
wreck diver
worcestershire
What are the pro,s or cons regarding de cat headers,with or with out the front balance pipe? thanks.
Give me a call tomorrow Rick and I'll tell you :thumb
Basically, the balance pipe balance to exhaust airflow for cooling. BMW would have spent millions on R&D and they do it for a reason. Keihan (the best:augie) and Akra keep the balance pipe but Remus don't but there headers are a larger bore to cope with the flow of exhaust gas.
To be honest, I'm sure you would find a difference on a dyno or if you were Rossi but I don't think us mortals would know.
If nothing else, the balance pipe just looks right:thumb
Thanks Chris.
I hav just been reunited with my 09 GSA,he had only ridden 2000 miles in 12 months:blast.
He has now gone for something more practical [ his words not mine],a Harley:nenau.
So as its now got a Akra can i am thinking of changing the headers,if its worth doing.
cheers:thumb2
Ah knew there was something i forgot:blast 1200 GSA.
Sorry - just because your profile says 1150 ;)
Don't think the benefits are as great on a 1200 myself having done it on both. You save several kgs on a 1150 and hardly any on the 1200. There's an improvement on midrange for sure. However I ended up removing them again from my 12 because I didn't like the extra noise with an open pipe (OTT) and I felt they had a negative affect on the fuelling - cant explain why and maybe it was my bike but was happier when I got rid of them again :nenau
Having said that been thinking about it again on my twin cam :D
Well I am pretty sure that if it was for an 1150 it would not be in the 1200 section, as them 1150 riders are far supirior or so they keep telling us:green gri
spike
Just checking as some of the 1150 guys seem to spend most of their time in this section these days :augie
In a nutshell:
Remove the CAT and you will get a slight boost in power as the engine can rev better. The low down and mid range grunt is also improved and the bike will seem that little bit quicker on the uptake. With the standard end can you will also notice a slightly deeper exhaust note.
If you fit an aftermarket end can and want to run it with baffles out, you will need a Power Commander to sort the fuelling as the bike will be running too lean. Baffle in, no problem.
If the bike has standard headers and an aftermarket end can, you will have a much louder noise but no increase in power or torque.
HTH
Your engine was running to lean with a straight through pipe and they don't like it. A power commander would have sorted that out. In my experience, you need some back pressure for the motor to run properly:thumb
Yeah that sounds about right - I also didnt like the popping and farting. Just got an akro silencer on the twin cam makes ferk all difference but it looks oh so nice :comfort
