For £14 I can afford to take a risk on one
That seemed likely from the cheap prices. It seems very good value, see how it goes, and whether I attain afterburn status or not.The seller tells me that they are closing down, so you might have won yourself the last one.
Being of a rather impetuous nature I’ve ordered a very expensive wood burning camping stove. I might have to cut a piece of perforated plate to stop pellets dropping through and it might be an abject fail but we’ll see.
We are now closed
January 2024 Thank you for visiting Wild Stoves. After 14 years of rewarding business, we are now closed and our website has been taken offline. Interested in taking on the business? [email protected]wildstoves.co.uk
Now one thing I do know is that pellets burn from the top down but there must be a way I can top it up without snuffing it out if it starts to run low.
I can’t help thinking you’re gonna fail again regardless because I’m sure it’s not meant as a pellet burner. I used some chopped up kindling ( didn’t have access to twigs etc ) and it worked brilliantly. It may well work fine with different pellets and I hope it does because it’s a great, cheap cooker.I was too lazy to shop around until I found the cheaper price.
Experiment #2 is due because I’ve got some pellets from a different supplier that I’d forgotten about so I’ll fill it with them and see how it goes. It might also be the case that it needs to pan support ring in place to push the gas in the right direction.
I can’t see me ever using it as a twig burner, I’m far more likely to use the smallest size Kelly kettle for that kind of game but if I can get good results using pellets or pine cones then it can stay.
Another cheap chinky knock off.
I need to read the instructions for mine, I didn't realise it could do that, I simplistically looked on it as a cheap stove. Seems it was even more of a bargain that I thought.Very popular on this forum, to put one up The Man and stiff the suits.
I already had a bag of kindling which I used with my Firebox so I used some of that. I’ve now chopped some more of the kindling up into cooker sized bits and put them into two zip topped bags ready for an adventure!The reason I’m hoping it’ll work with pellets is because once I’ve got it worked out it’s going to be easy to just put enough to boil a small kettle in a ziplock bag and drop it into the packed stove. I’m pretty much convinced I need to put a false base in to lift the fire closer to the pan support unless I’m going to fill it with fuel but only time will tell on that one.
Apart from that I need to get rid of the sciatica that’s been plaguing me for a fortnight then I can take the idiot dog to the woods and collect some pine cones and probably some prime sized kindling![]()
All I need to do now is grab the cooker, a bag of ready made sticks and job done. I already had a bag of kindling which I used with my Firebox so I used some of that. I’ve now chopped some more of the kindling up into cooker sized bits and put them into two zip topped bags ready for an adventure!All I need to do now is grab the cooker, a bag of ready made sticks and job done.
Hope your back gets better. I hate back pain. Always catches you off guard!
Smash the system, bro!Very popular on this forum, to put one up The Man and stiff the suits.
