Denali Horn and need for Relais???
albatross
Cheshire
Now here is a question …fitting a Denali Soundbomb..it does come with a Relais which it obviously needs .
But replacing the original horn on the 1150GS which has got a Relais, do I need or would it be advisable to fit a 2 nd Relais??
cheers for any advice.
If your original is already wired with a relay, I'd just wire in the new horn using the same wires as the old one and see how it goes. I'd expect that to be fine.
Thats what I thought Paul…was just double checking as I can not see the point of 2 relays..
let’s try and see, thanks anyway…
The original fuse for the horn is 7,5A.
If that is OK for your Denali, so you can use the original relay.
Seems to work fine, but I replaced the 7.5A fuse with a 15 A
all good….
Glad that I wasn’t able to close this one as the fuse blew after first attempt..
so you do need a relay as the Denali requires 20 A fuse and a 30 A relay …now all sorted…
