Sold Denali S4 lights - plus EZCan
richardbd
Sometimes here, sometimes there...
A pair of Denali S4 lights, fitted with hybrid lenses (two flood, two spot) for the best blend of seeing and being seen.
I chose these very carefully and concluded that they give the best blend between size and functionality. The D7s are brighter but not easily fitted to smaller bikes. These were on my 850.
The lights come complete with crash bar mounts and a complete wiring loom.
I also have for sale the Hex EXCan that was used to integrate these on my 850GS, allowing them to work with no additional switch gear, controlled by the OEM switchgear and to be programmed via laptop top to do all sorts of fancy strobing and things like flash when you sound the horn.
They're in great condition, with the exception of the scrape on the rim of one unit, caused by a bike-ground interface issue in the Canon del Pato last year. They work 100% perfectly.
These are really great kit and are only up for sale because I've sold the bike.
I'm looking for £275 posted for everything - lights, mounts, EZCan and loom.
I also have an unused set of yellow lenses for these, in a separate ad for £40.
Hi Richard
Will you split the lights and wiring for a sale please?
I don’t have a bike that needs that ez can so it’d be a waste for me to take it.
All the best!
Jim
These look like the D4.....
Hi again Richard
Wee bit of behind the scenes negotiation and agreement from two of us on here, and I’ve sent a pm to you.
Jim
Not wishing to usurp this thread but is it possible for someone to explain to me how this all works. I'm no sparky so don't have a clue. At present I've just got the bmw aux/fog lights with independent switch and was thinking of something more intense for the 1250, but no idea how to wire all this. Ta
When you fit the hex Ezcan, it's all plug and play. No electric skills needed to install the Denali lights.
You have amazing PM re your enquiry.
Great lights the D4s and a good buy at this price. Easily transferable between BMW bikes, I've had mine on 4 different boxers since buying about 5 years ago. Only the cansmart is bike-model-dependant.
