DENALI SOUNDBOMB
no01bignige
Member
Verwood,Dorset.
Hi Guys, I have fitted a Denali sound bomb, linked up to Denali Cansmart.
My question is, can I leave standard horn connected also.
I have mounted sound bomb to crash bars as not enough room under headstock as I have low suspension model.
Thanks for any response in advance.
I left mine connected but it sounded a bit odd so disconnected the OEM one.
Sent from my ELE-L29 using Tapatalk
If you connect in parallel - its fine and your insurance will be happy
change it from one to another and its a change that should be declared
DAMHIK ;)
I hope you're taking the piss.....
Sent from my SM-G970F using Tapatalk
Nope that what my insurer said. change it and its a requote - fit both and its no change to the policy
any excuse to wriggle
I had a factory low, the compressor will fit in the lh headstock area its how a bike thing ,did theirs
On his video, he stated it could not be fitted with low chassis. That is what I went by, never tried it. Also says this if you try to buy mounting bracket.
"Ideally mounted for use with the Compact Soundbomb between the forks.
Only fit this mount if your bike is a full standard frame height GS or GSA"
Indeed he does, and in another he states how they did it with a factory low
Found it - roundabout the 12 minute mark - it explains what & why
<iframe width="560" height="315" src="
" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
