different I-ABS III anti-lock phenomena
  • Thread starter Thread starter Dr.ABS Brake
Dr.ABS Brake
in short:
i do know every phenomena. but you cannot prove evidence! this is the point. since you cannot reproduce, you have nothing in your hands.
all you need is dead bodies. But then - you cannot prove dead bodies caused by BMW's famous design of anti-lock-brakes with brake booster.
i think you got the picture. if not: BMW Germany will not initiate a recall. and for them the actual debate about so called problems with the I-ABS III anti-lock-brake is officially closed!
Dr. ABS Brake (Germany)
NOT ONE MOTORBIKE MAGAZINE IN GERMANY WANTS TO REPORT ABOUT THE REAL PROBLEM WITH THE BRAKES.
THIS KIND OF BRAKES CAN BE VERY DANGEROUS IN CASE OF A FAILURE
ODI of NTHSA
Gesendet: Sonntag, 5. Dezember 2004 17:53
An: 'Bob Young '
Betreff: Letter to Bob Young [NHTSA]. Subject: BMW's I-ABS III Anti-Lock-Brake Failure's during ride
Wichtigkeit: Hoch
Dear Mr. Young,
I was recently informed that NHTSA is interested in failures of motorcycles, including BMW. A failure that might cause a crash could find your attention. I want do my part in bringing hazardous failures to the attention of the ODI.
ADAC Germany (Automobile Club) asked BMW Germany about the exact number of failures. BMW Germany did not tell the number.
http://www.advrider.com/forums/showthread.php?p=839471
http://www.advrider.com/forums/showthread.php?t=61479
http://www.advrider.com/forums/showthread.php?t=55058
http://www.advrider.com/forums/showthread.php?t=6356
http://bmwsporttouring.com/ubbthreads/showflat.php?Cat=&Number=431745
http://bmwsporttouring.com/ubbthreads/showflat.php?Cat=&Board=ride&Number=335451
http://bmwsporttouring.com/ubbthreads/showflat.php?Cat=&Number=384676
http://bmwsporttouring.com/ubbthreads/showflat.php?Cat=&Number=326413
http://bmwsporttouring.com/ubbthreads/showflat.php?Cat=&Number=333055
http://bmwsporttouring.com/ubbthreads/showflat.php?Cat=&Number=345771
http://bmwsporttouring.com/ubbthreads/showflat.php?Cat=&Number=322969
http://bmwsporttouring.com/ubbthreads/showflat.php?Cat=&Number=345801
http://bmwsporttouring.com/ubbthreads/showflat.php?Cat=&Number=408755
http://bmwsporttouring.com/ubbthreads/showflat.php?Cat=&Number=405880
http://www.ukgser.com/forums/showthread.php?s=&threadid=31481
http://www.ukgser.com/forums/showthread.php?s=&threadid=22981
http://www.ukgser.com/forums/showthread.php?s=&threadid=31333
http://www.ukgser.com/forums/showthread.php?s=&threadid=21562
IN GERMAN LANGUAGE:
[1] Der Autor schreibt: "... ist bei meiner 2003 S nun schon zum zweiten Mal der vordere Bremskreiskreis ausgefallen. Hatte nur noch Restbremsfunktion. Hatte jemand auch schon mal so ein Problem?" Im selben Artikel meldet sich jemand, bei dem vor 2 Jahren der BKV getauscht worden sei - weil sporadisch das ABS-Modul sich verabschiedet hätte. Der Autor des Artikels vermutet: "Anschlußpin vom Steuergerät defekt".
http://www.s-boxer.de/modules.php?mop=modload&name=Splatt_Forums&file=viewtopic&topic=6021&forum=27
[2] "das Problem war dass ich eine Gefahrenbremsung auf dem technischen Niveau der 1. Hälfte des 20. Jahrhunderts hinlegen musste: Massiver Krafteinsatz + absolute Nichtdosierbarkeit i.V.m. ABS-Ausfall = Vorderradrutscher, ich hatte Glück dass es mich nicht hingelegt hat. Ich hatte Pech, dass der Ausfall wohl kurz vor der besagten Gefahrenbremsung erfolgte und ich die Lampe noch nicht bemerkt hatte..."
http://www.boxer-forum.de/dc/dcboar...um=7&topic_id=45387&mesg_id=45387&page=#45425
[3] "Sofern aber ohne Kenntnis des Nichtfunktionierens und im Vertrauen auf das Funktionieren des BKV eine Gefahrenbremsung durchgeführt wird, bei der das ABS nicht zur Verfügung steht und eine Restbremswirkung von 5 m/s erreicht wird, stellt dies aus meiner Sicht eine Gefahr da."
http://www.boxer-forum.de/dc/dcboar...um=7&topic_id=45387&mesg_id=45387&page=#45513
[4] Zwischenergebnis ABS - Umfrage
http://www.boxer-forum.de/dc/dcboard.php?az=show_topic&forum=7&topic_id=45963&mesg_id=45963&page=
[5] BMW R 1150 GS DZ 03/03 15000 km -Ausfall des BKV
http://www.boxer-forum.de/dc/dcboar...um=7&topic_id=45387&mesg_id=45387&page=#45929
[6] Verzögerter Bremseinsatz des I-ABSIII ?
http://www.bmw-bike-forum.info/k1200lt/viewtopic.php?t=1749
[7] ABS-Regelfunktion auf schlechten Landstraßen ?
http://www.r1200gs.de/phpBB2/viewtopic.php?t=656&start=0
Sonstige Threads:
[8] http://www.k1200rs.at/forum/viewtopic.php?t=5679&postdays=0&postorder=asc&start=0
[9] http://www.bmw-bike-forum.info/r1150r/viewtopic.php?t=885
Beide Threads wurden initiiert, da der SiteAdmin „durch einige Meldungen und Leserbriefe aufgeschreckt (MO)“ war, „in denen Probleme mit dem ABS 3 geschildert wurden (siehe z.B. Leserbreife und Test RT 1150)“. Ich kenne die Meldungen und Leserbriefe nicht, habe bei MO allerdings in dieser Angelegenheit angefragt.
Inhaltlich ist der erste Thread ergiebiger …
Im zweiten Thread ist der Bericht von KRIEGER interessant. Er bildet meinen Fall 1:1 ab. Entweder die Bremse bremst nicht – oder sie blockiert.
Zitate:
„ich hab das komplette Integral-ABS in voller Fahrt verloren. Sehr unschön, als dann der Traktor vor mir auf die Strasse bog... hatte kurz davor schon Probleme, die sich aber durch Zündung aus/an beheben liessen, bis es mich dann beim Fahren erwischt hat. Die Werkstatt war hyper-nervös und hat erst den Fehlerspeicher ausgelesen (mehrere Seiten) und dann das gesamte System ausgebaut und nach München geschickt... ist alles auf Kulanz behoben worden, seit dem habe ich keine Probleme mehr. KM-Stand damals: ca. 11.000, aktuell 40.000.
Problem dabei: kaum Bremswirkung, und die auf den Bremskraftverstärker abgestimmte Bremse ist ohne praktisch nicht dosierbar: entweder sie bremst nicht oder sie blockiert (wie bei mir)“
If you want to get some feedback from this site (& I am sure there's some good information here for you), you must post a synopsis of all your above posts in English. Good luck with your project...
Mike:)
