martin
93 GS 1000
when braking with front, it all seems a bit squeeky. I thought perhaps salt etc had got in. On further investigation found this . . . . . . The rivets holding the disc seem to be worn. Surely, thats not wots meant by a "floating disc" ???
If I hold the front brake on, the calliper clamps the disc ok, but there is a certain amount of play forwards and backwards in the wheel. Ie, I can actually rotate the wheel with the brake on, albeit perhaps only a millimeter or 2, but enough to be spotted easily.
The rivets seem to allow sideways movement in the disc, which i can understand, but surely not in a rotational direction ?????
Thanks all, in advance
Martin
ps . personal emails to [email protected] if you prefer
Martin
