Brake Disc Mounts Question
PhaedrusMC
Dublin
Play in my right disc prompted me to order 10 of these wave washers from James Sherlock: http://www.james-sherlock.co.uk/sho...ront/brake-disc-mounting-sprung-washer-detail
Turns out that while there is lateral play, there's also vertical/fore-aft play, so I don't imagine wave washers will address that. Yes I'm a muppet for not spotting that before.
So I now think it's the bobbins that need to be replaced. Is it de rigueur to replace the bolts too?
With the 10 x wave washers I've already bought, if I now buy 10 x bolts (https://james-sherlock.co.uk/shop/r...ittings-front/brake-disc-mounting-bolt-detail) and 10 x bobbins (http://james-sherlock.co.uk/shop/r8...tings-front/brake-disc-mounting-bobbin-detail) this will effectively create 2 of this kit (which is what I guess I should have bought in the first place :blast): https://james-sherlock.co.uk/shop/r...c-fittings-front/brake-disc-repair-kit-detail
Until I do use those replacement mounting bits, I presume I won't know if the holes in the discs that the bobbins fit into are worn too? If the new bobbins don't eliminate the play, do I need new discs? My discs seem grand - still as thick as if they were new, with no scoring.
TIA. :thumb2
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/322495388769
you can also rotate the existing bobbins 90 degrees so that the worn flat spots are no longer at the mating face. may have already been done though. personally i would just replace given the relatively low cost.
Absolutely will replace bobbins, bolts & wave washers. My concern is that it could be the holes in the discs that could be worn rather than the bobbins - is this common?
Thanks for that ebay link. :thumb2
