Discrepancy between fuel gauge and Empty light (1150)
RSavage
Sevenoaks
Does anyone know what drives the 'Fuel Low light'? And what could cause it to malfunction? Mine came on after only 128 miles riding from a filled tank and with 5 or 6 bars still showing on the fuel gauge yesterday. I then filled the tank just to prevent running out of fuel with only about 15 litres so the gauge and mileage were more believable than the idiot light.
I had ridden 700 miles in the National Rally when this happened but the idiot light had not miss-behaved until that point.
I will be draining the tank up in a few weeks when my S4 siphon arrives so opening it to look at any in-tank senders is not a problem.
Any thoughts?
TIA
Richard
Try cleaning the contacts on the block connector on the off side of the tank.
Taking the pump/fuel filter plate off can sometimes cause problems,but since you haven't mentioned that,i would go along with dirty/corroded pins in the 4-way tank connector as mentioned.
Thanks to both.
A bit of contact scrapping was to be my first point of call - after draining an almost full tank :blast
Richard
Always try the easy stuff 1st........:D
