Displaying more than one route
Wapping
Moderator
Wapping, London
MyRoute has always been able to displsy more than one route at a time. The downside was that each additional route had to be selected individually. The latest update now allows ALL the routes in a folder to be selected and displayed at once, removing the need to load each route singly.
There’s one thing to be aware of - it will only add a max of 20 and doesn’t include sub-folders.
Not a major issue, but may save some head scratching for people unaware.
Had a look, but can’t see how you do it.
When viewing a route, click the 3 lines next to the waypoints on the LH side. Click Routes > Add > then select a route.
The map will then show the routes simultaneously. And you can add way points to link the routes together (if needed).
A great feature i'll use moving forward to help make sure any longer routes i've broken up still link. And great for checking loops out from accommodation to cover good roads in the area, or not use the same bit twice!
Pretty much what it designed to do.
I put my routes out from home and back into one folder. Then I create separate folders for jaunts out. For instance, staying at town A as a hub, I put those jaunts out into a folder for town A. Likewise, a separte folder for town B and so on.
But, what makes sense to me, might well be totally different for someone else.
it's the same as what i do. Categorise everything!
