Wanted to mount my Zumo where I could see it easily on my 07 GS, so didn't find the included RAM mounting kit suited my needs (though will use it for Photographic/video stuff at some point).
In among a box of old bits and pieces I found a suitable strong, straight bracket about 5" long by 3/4" wide by with a 1/4" hole at each end. I attached this with a nut and bolt to the windscreen mounting bracket and at the other end I attached a small ball and socket camera mount. On the Zumo bracket I made a small bracket with a 1/4" Bolt on the centre of it. This enabled me to mount the Zumo Bracket to the ball and socket head. The final position lines up nicely with the instrument panel and perfectly in line with my view ahead. Before anybody asks I am afraid I don't know where you can get the ball and socket head. I have had a few of these lying around for years. In fact I have one mounted on my left hand handguard which I have used for taking videos. However from the side views it can be seen that a single piece of metal bent into an L shape could be used.
Have attached photos which probably make the above clearer.
