BigKev67
Does anyone know if the current dynamic ESA still has adjustable spring rate.
I know that the bike adjusts rear spring pre load each time you set off according to how far the rear shock is compressed - this will achieve optimal SAG.
What I am not sure about is SPRING RATE.
Some years ago My RT had a spring consisting of two elements, a conventional coil spring, and an elastomer contained within a sleeve. The ESA moved the sleeve to vary how the elastomer was restrained, and hence the stiffness of the elastomer varied creating a change to the overall spring rate.
What I dont know is whether this adjustable elastomer is still used in current ESA as its its not mentioned anywhere.
