Does this driveshaft need changing?
Danny996
Member
Eastbourne
Was greasing the driveshaft splines and noticed they look worn compared to the gearbox end. They look very narrow. The joint at the final drive end isn’t notchy but drops down under its own weight.
I’m guessing this means it’s time for a new or decent second hand one?
I also noticed oil in the swing arm, it was fairly clear/golden looking, and there was a bit on the boot at the final drive end, gearbox end boot was dry. I’m guessing the most likely culprit is the final drive inner seal? It’s got a fairly new rubber boot on the final drive end so don’t think it’s from water egress.
Having had one snap on me, on the M25 when it was dark and wet - when filtering, i would not risk it. Whilst the likelyhood is that it would just spin on the male section, my experience of the wheel locking up when filtering means I now pay far more attention to the driveline, including the correct, expensive grease etc.
Valid point! I will look to buy a new one. Has anyone on here bought the rebuild able one from motorworks? There’s is £540 and a bmw one is £700. Im wondering if it’s better to opt for the rebuild able version?
How old is your bike and how many miles
say its a 2011 TC so 15 years old £700 /15 = £46.66 a year less than a pound a week - small change
just do it, its the right part for the bike , comes with a manufacturers warranty
Personally I'd go for the rebuildable one and your current one looks well past it!
Don't forget the correct grease for the splines.
This
I’ll look into the warranty on the rebuildable ones. Got the grease already. 👍
I have had trouble with the rebuildable one, vibrations from the drive line. I was lucky to get it refunded even after using it a while. I opted for the oem shaft and my troubles were gone after that.
The first one lasted 15 years and 40k miles, which isn't too bad I think.
Ah ok, thanks for the info. I think it might be better to go oem. Same age as mine, and similar mileage.
I'm constantly surprised at the variation in serviceability of BMW parts. Some people are experiencing components like drive shafts failing, or showing excessive wear, quite early in the bikes life. Whereas others seem to last forever. I checked my drive shaft 6 months ago, and it looked like it had just been made. My bike is an 09 GS with 91k on the clock.
Is it the down to the way it's ridden, the servicing, what day it was made, or just luck?
I've wondered exactly the same thing. I've decided it's just luck. Cars, bikes etc are a huge collection of parts, it's a testament to industrial manufacturing processes, standards etc etc. that we have such an abundance in so many varieties - I am forever impressed. But a few things can line up and create either a bad apple or a great one. The rest are an acceptable somewhere in between.
Saying all this, I personally believe lack of use is a factor too...
I agree totally with you Slipperyeel with regard to lack of use. Oil drains down into the sump, oil seals
and O rings dry out, and batteries discharge.
This
This post was a few weeks ago so you may not see this.. I thought the staburags was for the rubber boot? I have castrol moly ta ( which is a white paste ) for the splines.
