DP ceramic backed sintered brake pads
Steptoe
Him/Bloke/Fella.
S/W London.
As well as the [URL="http://www.ukgser.com/forums/showthread.php?t=101142&highlight=brake+pads"]Ferodo[/URL] pads i supply, i can now offer DP sintered brake pads. Made in the UK, and used by many race teams here and in the usa.
I've been testing them on the loan bikes and they are very very good.
Standard backing for the 1100 and early 1150 models.
Ceramic backing on the later 1150 and all 1200 models. Ideal for servo braked bikes.
All available at the gsshop.co.uk.
Bought a front set off you.... and can confirm I have not died in a braking related accident, as of this time.
Price is good also.
:thumb2
Neil, dya have the DP ones for the rear caliper. 1150advservo
Thank God for that...I was thinking of starting a race team using GS1100's...cos everyone knows they are the fastest bike out there when correctly ridden...but i didn't have a braking solution...till now :D
I do have DP rear pads that will fit, but they aren't the one pad thicker than the other type that are usually used on the rears of BMW's..
If you know what i mean....
What advantage does the ceramic backing have??? I'm guessing it's something to do with heat transfer :nenau
A genuine question. I'm not digging...:)
Yes, keeps the temp of the brake fluid down, especially relevant on servo brakes used hard.
Apart from OEM (generally), I think DP Pads are superb:thumb
Can you supply for the F650GS also
Know what you mean.
I never use the back brake ..... it uses itself.
Neil ... if you have my address on record, send me a set please. How much?
Know what you mean.
£15 - i'll check back in my records:eek for your address ..
