sopwith camel
Now I'll the first to admit that I'm not particularly mechanically minded, but even I can manage an oil change - or least I have been able to on my previous bikes.
My 1150GS seems a real pig to drain though?? For starters the sump plug is sandwiched between the cylinder head and the exhaust down pipe, which means that the oil will drip straight on to the pipe - I've had to make a funnel to get round this. I can't seem to get the plug completely out either because of the exhaust pipe. And nothing comes out at all unless the engine is up to running temperature, and even then it's v. slow. Oh, and why is the plug on the opposite side to the centre stand so I can't even lean the bike the wrong way.
Now either the Germans really haven't thought this through properly, or more likely I'm unscrewing the wrong plug or missing something very obvious, in which case those reading this will be thinking what the ****???!!
Can anyone help a clean handed desk jockey with the most simplest of tasks...??
Sopwith
Sopwith
