Drift ghost XL help
Dave56
Yaxley, Peterborough
Just wondered if anyone can help me out with an apparent issue I’m having with my Drift Ghost XL camera.
Previously after a lengthy ride I’d go to download the video files from the SD card would consist of numerous 20 minute files.
Now for some reason that I cannot fathom when I come to download the files from the SD card it consists of 400+ 2 minute files…..!
Is it something that I’ve inadvertently altered within the settings or is it a problem with the camera itself.
So I just thought that if anyone has had a similar issue how did you solve it. :nenau
Dave, have you inadvertently switched on the Dash Cam mode?
In Dash Cam Mode the Ghost XL will power on automatically
when it detects a power supply. Connect the camera to a car or
motorcycle power supply, and the camera will turn on and start
recording when the ignition is turned on. When the ignition is
turned off, the camera will save the footage and then power off
instantly.
The interval setting is the duration of the loops that the Ghost XL
will record. For example, if you select a 2m interval and record
for 20 minutes, you’ll find 10 videos saved on your memory
card, each two minutes long.​
Hope this helps
instantly.
Hope this helps
Thanks for that, I’ll check it out, it certainly sounds very feasible.
