LakesRider
So, without igniting a debate about whether this is worth doing or not....
I have bought a 2008 R1200GS. 43k miles. It is very clean, but as part of a service I would like to check the driveshaft and make sure that it is not rusted into the final drive. To be honest, I am just interested to see how well it has been maintained and cared for.
I have bought the bits I need to change the final drive oil from MotoWorks, and at the same time I will try to drop the final drive off the driveshaft and clean and lubricate the splines and check the gasket.
I have seen all kinds of opinions on this, but the general idea seems to be that it doesn't hurt to do this job each year.
My question is, what about the gearbox end? As I haven't owned the bike from new, and it has had independent servicing for the last few years, I wouldn't mind checking the gearbox end, even if it doesn't need done as regularly? Can I try to pull it out through the swingarm without levering it off at the gearbox end? The access looks tight at that end! I assume if it is corroded at all, I will need to ease back the gasket at the gearbox end to lever it off, and for reinstating it into the gearbox when it is cleaned and greased? I have also read about a circlip on that end - does that need to be accessed and removed first and reinstalled later?
Anyone who has done this job, I would appreciate any advice. I would quite like to remove the whole driveshaft just to feel it is in good order.
Any advice from someone who has done the job gratefully received.
Thanks all
Phil
Thanks all
Phil
