Benhur Malta
Hi all,
background - bike has had recent oil change filter change runs normal ron 95 octane fuel has had throttle body sync both at idle and the throttle cable sync at 3000 rev. Bike runs beautifully without vibration. Bike also has a wunderlich fuel controller installed (which richens the mixture). however air filter is stock and cat box is installed with a remus can. I have recently also done a motronic reset by removing the fuse for 15min and then after reinstalling opening the throttle full 3 times after each other.
My query is that when driving and coming off throttle the idle drops down to 900 and then climbs to 1100 approx. This when warm. When cold the drop is more severe. i read somewhere that this means that the mixture is rich at idle. First off, Is this correct?
Is there any way I can improve this for now without removing the fuel controller? (maybe using a K&N air filter). I would like to keep the wunderlich installed because I plan in future to remove the catalyser (need to find one not too expensive).
R.
R.
