Drum brake hub repair
scots_jon
Pewsey, Wilts.
Hi All,
I'm sorting out a mates XT350 for it's MOT and having difficulty with the rear drum brake. The cast drum lining has cracked meaning the brake runs out and generally doesn't work well. Is it possible to replace the cast bit? Or weld up the cracks and grind flat? I'm not hopeful here...
Been a long time since I've had to deal with drum brakes. :)
Cheers,
Jon
drum brake
your best bet is to buy another wheel from a breaker
I would not trust a repair of this type
regards
Steve
Motoscot :oonyack
parts are cheap an plentifull, look on ebay,
you can get it repaired , but it prob wont be worth it
