Mine has packed up, DELL computer. Bought a new one and fitted it. Nothing happens. Its not detected as D drive at all. What am i doing wrong.
One thing defeated me. In the manual for new dvd thingy theres a bit about slave/master etc. It has 3 lots of pairs of pins with one connect thing that came fitted to master. t then says
If you only connect one device on the cable, you can set the jumper to master or slave
If you connect two devices (eg CD ROM & CDRW) on the same cable, the jumpers must be set differently for each device(CD ROM as Master, CD RW as Slave and vice versa) The same rule applies to the connection of having your hard disk and another device on the same cable.
Has anyone any idea what this splather means. I'm lost.Whats an IDE port or IDE cable??
Help???
Help???
