NeilF said:
Went to Costco to buy some DVD / CD disks - just for music in the car, or sending out with photos on them.
Crikey - all sorts of specifications on the boxes!
DVD-R
16x
80x
gold
silver
What do these 'specifications' all mean? What's the basic recommendation for buying disks?
For example, I seem to remember I couldn't get an 80x disk to play in the car CD player.
Cheers,
Neil.
Well, some confusion here I think. Does your car player play DVDs? If not you should stick to CDs.
Either way you need to determine which type(s) your player plays, and which type your recorder writes, and how fast each of them will work.
You can't (necessarily) play CD-Rs at all in a CD player; they don't all work with them. You can't play a DVD+R in a DVD-R player or vice versa, but if the player supports DVD+R and DVD-R then you can use either type of disk. The same is true of CD+R and CD-R but unless it's a dead old player there's a good chance it'll support both.
If your computer only writes DVD+ and your player only plays DVD- then you're stuffed and you'll need to get a DVD- writer. (Ditto for CD; both + and - types exist although that difference was resolved years ago in the form of multiformat players.)
The speed of the disks is relevant in that the faster disks are subject to more stringent manufacturing requirements and are usually more expensive. If nothing will play over 4x, for example, and there are 4x and 16x in the shop with a significant price difference, you should get the 4x. If there's no price difference then you should go for the 16x as you can always play/record them in a 4x drive.
The "if this, if that, if the other" decision tree is large and confusing so I won't go any further. RTFM - for the computer and the car player, and determine exactly what disks they play and record - CD or DVD, + or -, speed, post that info and we can give you a specific recommendation.
