Dynamic cornering lights -Hex Innovate
Flipfly
Stoke on Trent
So, I had a play with DCL on the Hex EZCan, it works well on dipped beam, but when on full beam, it’s actually dimming the light rather than just leaving it on full beam.
Just a heads up, they are aware of the issue and the devs are working on a fix 👍
Don’t go round in circles trying to fix it like I have been doing 😂😂😂
If you have the older pre LC version,
you can enable / disable the centre speed spot via a combination of high / low beam and button presses ( it may work for the LC too) but according to the manual you can only do it via the software
Different thing.
The dynamic lighting is supposed to brighten the light on the inside of a corner (like a cars cornering lights). The problem is, it kicks in when you are on full beam and because you would have it set on a lower % value for dipped lights, the light actually dims on full beam making the view worse when on full beam (which is when you want maximum lighting). It’s actually kinda dangerous.
Hex still haven’t released an update that I can see but are aware of the issue.
