EBC brake pads??
Yodagoat
East Lothian, Scotland
I just changed the rear pads on my 1150 (servo, ABS) I got EBC pads from motoworks. When I put them on and re fitted the caliper the caliper appeared to be sticking. I took it all apart again and gave everything a clean. The calliper is not sicking and moves freely. I re fitted the pads and noticed that the don't seem to fit properly, they rub on the calliper causing it to stick slightly. before I file them down a bit, has anyone else had a similar problem??
Mike
Yep although it was a couple of years ago, got mine from Hein Gerrick, and was told might have to file them a wee bit. I would give motorworks a call just to confirm. They went in ok after a bit of filing, never fitted them again as I found that they did not last as long as BM ones so concluded it was a bit of a false economy. However mine is a non ABS so that may or may not make a difference.
Simon
:beer:
